'70 LT-1, CTK, 350/370, Original motor. 49,000 miles on clock.
First off, the engine was running fine, using a little oil so I thought I'd work the heads. The heads ended up needing substantial work, but that's another story.
Compression check before removal yielded:
1-149
2-143
3-150
4-140
5-135; wet-140
6-140
7-135; wet-140
8-145
Upon cleaning the block for head re-install I noticed that number 5 and 6 cylinders had steel inserts installed and there was a crack going from the outside of the insert (What would normally be the cylinder wall) to one of the head bolt holes. #5's crack went from the insert and to the top thread only of the bolt hole. In other words, the crack was not all the way down the threads. #6's crack also went from the old cylinder wall to a bolt hole, but that hole has been bored out with a threaded insert installed. (Like a helicoil, but a solid threaded insert)
My dilema is what the heck to do. Were the inserts installed to repair the cracks, were the cracks caused by the inserts? Am I scr***d? Did I mention that the engine was running fine and I shouldn't have started this project.
I guess my question is, are the inserts a good fix for the cracks. Has anyone had experience with this type of block crack?
1-149
2-143
3-150
4-140
5-135; wet-140
6-140
7-135; wet-140
8-145
