Ball Joint replacement - NCRS Discussion Boards
  • robert vargas
    I have purchased a suspension kit from ZIP and when installing the lower ball joints, there are 2 bolts that hold the ball joint to the a-arm. One is a regular black standard bolt and the other is a zinc plated bolt that has an extended round head on it? Which goes where? And what is the plated bolt used for?
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: Ball Joint replacement
    I have seen that special bolt on the front side of the A arm. I am guessing it might be a stop limit for the steering in some Corvettes.
    Lyle
