I need info on spindles & rotors.First off my car has been sitting for several years.A short time before car became idle I had new bearings(rear) pressed on spindles(car has 90k on it}.The job was done by friend of friend deal.I'mm wondering if job was done correctly after reading some of the post on discussion board.I'd like to know two things. What is it I need to do when replacing rotors as far as matching them properly on spindles?Also how should I have bearings checked for proper installation?(clearances)
