Automatic Trans. wiring - '65 PG - NCRS Discussion Boards
  • Ryan Clark
    I have a question about the Neutral Safety Switch wiring for the Powerglide.
    The PG in my car was installed by a previous owner, originally a muncie 4-speed.
    My understanding is that this wiring is supposed to prevent starting the car in any position other than Park or Neutral. Is this correct.?
    Based on the AIM, there should be 4 wires; 18G-B/LG, 18G-DG, & 2 12G-PPl.
    The two 12G-PPl wires run thru the firwall and connect to the engine wiring harness. These wires are connected. According to the AIM the 18G wires should be connected to the interior wiring harness. I recently pulled the old harness to replace it with one purchased from Lectric Limited. These two wires were not connected to anything. My real question is what do the 18G-B/LG, 18G-DG wires control.? And what color wires on the new harness should these be connected to?
    Another question concerning the fuse panel and wiring harnesses.
    A previous owner bypassed the fuse panel with the hot wire, 12G-Red. I read a couple of posts on the corvette forum site that says this is a somewhat common practice because the connection thru the fuse panel isn't the greatest. Are there any potential problems in doing this, or is it acceptable. The car is a driver so I want reliability.
    Ryan #35188
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: Automatic Trans. wiring - '65 PG
    I dont have the diagrams in fron of me but I know the purple wires are the starter wires. They are the ones that control the starting. The others should be for the back up lights. The wiring splice is a very common repair. If it is done well it should be safer than the original, because the connection will not get hot. If may cause difficulties if you need to unplug the bulkhead connector for any reason, but that shouldnt be much of a concern.
