Paint questions 1967 - NCRS Discussion Boards
  • Keith B.
    • December 1, 1991
    • 397
    Just did a quick visit to the paint shop. It is amazing how a nice red laquer can make your heart skip a beat or two. I have a couple of detail questions. Should the color of the back of the hood be rubbed. I suspect no because they would not have had time between color and black out and the underside of the hood was not originally primed?. Also I can see slight imperfections in the black and in the red (on the 1 inch edge) with a little of the fiberglass strands visible. The top surfaces will not have this because of the additional prep and primer/surfacers. I am painting in Laquer so it shows everything. Is this common how a factory underside of a hood would look like. I know they weren't perfect but I want it to be correct. I simply stripped the old paint off and did put light primer down for adhesion. Thanks for your responses.
    Keith
    Keith Burmeister
  • Bill W.
    • March 1, 1980
    • 2000
    Re: Paint questions 1967
    I think the factory did put a light coat of primer under the black out , just one color. Yes you should see all the little strands and grain of the fiberglass in the black out areas .The painted underhood & gutter lips ,fender vents ,bottoms of doors and fenders , will also show some texture .lacquer soaks into the pnls. as it dries . original paint cars will show a slight amount of texture in all upper pnls.this cannot be duplicated using modern primers & paints. good job! Bill
    • Bill W.
      • March 1, 1980
      • 2000
