66 Courtesy Lights - NCRS Discussion Boards
66 Courtesy Lights
  • Grant M.
    • August 31, 1995
    • 448
    Re: 66 Courtesy Lights
    Frank,
    I had this problem years ago with my '65. I solved it by removing the plastic base plate from the socket, and replacing it with those parts from a generic replacement socket purchased at an auto parts store. The replacement item needed a little t******* to fit the older socket exactly, but the new spring and clean, new contacts made the bulbs work as intended. A 'cheap' fix.
    good luck,
    grant
    • Grant M.
      • August 31, 1995
      • 448
      Frank,
      good luck,
      grant
