Shifter arms problem - NCRS Discussion Boards
  • Jerry G.
    • April 1, 1985
    • 1022
    I have a 65 FI with a close ratio trans. It had a Hurst shifter when I got it many years ago. The time has come to put original linkage back in it. I ordered the shift arms from LI corvette and went to put them on. They won't go over the rectangular ears that stick out from the transmission?? The are the same shape and seem pretty close but just don't slip on. The other strange thing is the bolts that hold the arms on are 3/8 16 . They won't go through the hole in the arms to mount the shift levers. The old Hurst levers had an enlarged portion so the bolt could go through What am I missing??? Jerry
  • Larry Low
    Re: Shifter arms problem
    You have the wrong model transmission. I believe '69 Muncie's up started the use of 3/8-16 internal thread w/bolts. '63 thru '68 had external 5/16-18 w/nuts.
    • Larry Low
      • Jerry G.
        • April 1, 1985
        • 1022
        Cover part # 3950306
        Is this the correct part number for a 65 M21?
        • Jerry G.
          • April 1, 1985
          • 1022
          • Jerry G.
            • April 1, 1985
            • 1022
            anyone have a 3831707 ? *NM*
            • Jerry G.
              • April 1, 1985
              • 1022
              • Larry Low
                Re: anyone have a 3831707 ?
                Give this guy a shout, do not know him, but have seen him post parts at other sites, crash_enterprises@yahoo.com
                • Larry Low
                  • Jerry G.
                    • April 1, 1985
                    • 1022
                    Thanks larry *NM*
                    • Jerry G.
                      • April 1, 1985
                      • 1022
                      Thanks larry *NM*
                        Re: Cover part # 3950306
                        Jerry-----
                        GM casting #3950306 is a 69 side cover. However, you need more than just the correct side cover to correct this problem. You also need the correct shifter shafts with the 5/16" studs. These were GM #3831709, but they were discontinued years ago. No reproductions that I know of are available and used ones are often scrap.
                          Jerry-----
                            Try Auto Gear Equipment, Syracuse, NY (800) 634-3001 or 4-Speeds by Darrell, www.pipersauto.com .
