New Coker Radials - NCRS Discussion Boards
New Coker Radials
  • John Mathieu
    New Coker Radials
    and, the the fellow got grease on the gold lines! Any help on getting this grease off?
    Thanks in advance.
  • Peter M.
    • February 1, 1984
    • 361
    Re: New Coker Radials
    Try a little waterless hand cleaner and a sponge to remove the grease - then you can brighten it up will a light touch with brillo and water. Worked wonders on my Goldstripe Cokers
    • Peter M.
      • February 1, 1984
      • 361
      • Jerry Clark
        I have heard this is a no no so many times yet I used Lacquer thinner to clean my red stripes for six years...spotless
        did I get some red, yes the rag was always have a hint of red after all four but, after six years they were still bright and red.
        Just my experience
        jer
        • Jerry Clark
          Just my experience
          jer
          • Craig S.
            • June 30, 1997
            • 2471
            Has anyone tried Westleys Bleach White on gold or redlines? If the tires are true red/gold rubber and not the grind down paint on type, I would think this product would work well as on whitewalls or white letters....just curious. I have a set of Coker redlines that I have installed on the wheels, but have not mounted on the car yet..Craig
            • Craig S.
              • June 30, 1997
              • 2471
                • 11608
                Westley's
                I use the Westley's on my Diamondback Classics redlines all the time and it works great. I've never tried lacquer thinner, band really see no need to do so.
                Patrick
                  • 11608
                  Westley's
                  Patrick
                  • John Mathieu
                    Shiny like new. Thanks! (Permatex Hand Cleaner)
                    • John Mathieu
                        • 15610
                        Re: Westley's
                        New tires typically have a lot of mold release agent on them. That's the stuff that eventually turns brown. I've found that mineral spirits is the best way to remove it, and Westleys Bleach-White is excellent for keeping the tires clean after that, but don't get it on bare aluminum wheels. Westley's has phosphoric acid in it, and it will etch uncoated aluminum.
                          • 15610
                          Re: Westley's
                          • Craig S.
                            • June 30, 1997
                            • 2471
                            Re: Westley's
                            Thx Patrick and Duke! I have always had great luck with Westleys on all my other tires, and just assumed it would be fine for the redlines too. Thx for the tip on the mineral spirits to get the mold release agent off...Craig
                            • Craig S.
                              • June 30, 1997
                              • 2471
                              Re: Westley's
