C3 1968 dash mounted ignition - NCRS Discussion Boards
  • JOHN MELVIN
    Re: C3 1968 dash mounted ignition
    Larry is correct. The lock cylinder just pops out. Dicsconeect battery (jusy in case)put your key in the ignition. Take a paper clip, and insert in the hole in the face of the cylinders. Press slightly in while turning key back and forth. The cylinder will pop out. You will have to do it anyhow, to remove the swtich bezel, and the switch housing
    • JOHN MELVIN
