Re: Hood Adjustment - NCRS Discussion Boards
Re: Hood Adjustment
  • joe tassoni
    Re: Hood Adjustment
    i had this problem on a 68 convertible, it became quite frustating, i finally solved the problem by slightly loosening the cable that ran from the drivers side hood latch to the passenger side latch. be careful as i'm sure you know, you can get the hood stuck in the closed position if you over adjust
