Can somebody PLEASE let me know the best way to get out a thermosat bolt that broke off into my intake manifold. I have about an inch above the manifold to play with? I believe the bolt has been there for 35 years, so it is not coming out to easy. Thanks to anybody that might be able to help.
bolt stuck in intake manifold - C2
Re: bolt stuck in intake manifold - C2
Mike-----
This type of situation is always very difficult. In the interests of not damaging the manifold, I would strongly suggest taking the manifold off of the car (if it's not already) and taking it to a very competent machine shop, preferably one that has EDM (electroless discharge machine) capabilities. They can determine if the bolt can be machined out or if EDM would be the better route. In either case, you will likely have to have the hole drilled and heli-coiled, but that's no problem, at all. You will end up with an undetectable repair that's as strong or stronger than the threads were originally.In Appreciation of John Hinckley- Top
If the manifold is cast iron, you can heat the area around the broken bolt and free it up. You can probably turn it out with vise grips, or weld a nut to the end. If there are useable threads all the way to the end, you can double nut the stud and turn on the lower nut.
If it's aluminum, you can still use heat, but you need to be VERY careful and use less heat. I would try just about everything else first, including lots of penetrating oil. The methods of turning the bolt remain the same.- Top
Re: Bolt stuck in manifold
You'll need a welding torch to do the job... you can try a propane torch, but it may not be able to concentrate enough heat quickly enough to do the job... you need to get it cherry red. I've heard (haven't tried it) that you can touch a candle onto the hot stud, while you're doing this, and the wax will penetrate the threads to help loosen it.
An off-the-wall thought: if all else fails and you don't want to remove the manifold, you could file the broken part down to get a flat top, then use a die to cut new threads on it and use it as a stud.- Top
Mike, if you try heat the trick is to heat the surrounding area quickly. I would take the manifold off the car due to fire hazard. If you don't have an acetylene torch, take it to a machine shop. They probably won't charge you much to take it out and they have experience.- Top
Thanks to eveybody who has replied to my message. I have decided to take off the manifold and bring it to a machine shop. I rather have somebody with experience do the job. Anyway, this give me a chance to get it sand blasted and repainted.- Top
Mike - when you get the manifold home, pay strict attention to ensuring that ALL glass beads are flushed from the manifold before your paint and install it. Sometimes machine shops don't completely spend the time and attention on this, and expect that the customer will do the final prep. Nothing is worse than running your engine and having it suck some glass beads into the cylinders....Craig- Top
If you can weld I can tell you how to get it out properly.
Place a steel washer on the exposed stud, weld the washer to the exposed stud, next weld a short scrap bolt to the washer, while still hot loosen slowly with awrench. This is always successfull!- Top
