mid year clutch pedal removal - NCRS Discussion Boards
  • Larry S.
    • August 31, 2000
    • 356
    I would like to remove my clutch pedal in order to see why it binds and also install 2 new bushings looks like I have to pull down that whole bracing (firewall to dash board) is this correct to slide out clutch pedal any tips /suggestion are apreciated 66 big block roadster
  • Dave#24235
    Memory tells me the bracket comes out......
    and it is harder with a-c ducts. Are you sure that the bind is in the pedal? Mine squeaked, or I wouldn't have replaced the bushings. - Dave
