My Flywheel post on 8 Aug - NCRS Discussion Boards
    • December 1, 1999
    • 97
    For anyone who is interested:
    Quote
    Flywheel
    Posted By: John Hanchak #33298
    Date: Thursday, 8 August 2002, at 1:42 p.m.
    Can someone identify and provide the application of a flywheel with the casting number "14091559N". It bolts up to a late model Chevy crankshaft with a one piece rear main seal. This FW has the ring gear teeth for the starter on the transmission side rather than the engine side. TIA, John.
    Unquote
    I was able to remove the ring gear from the flywheel by gently tapping it off with a soft punch and a 2# hammer. I reassembled it by heating the ring gear in my wife's oven at 400 Degrees for a couple of hours while I took her out to dinner - at the same time, I placed the flywheel in the freezer for the same period of time. After dinner, I gently dropped the ring onto the correct side of the flywheel - it dropped right on down to the sholder and immediately shrunk to fit tightly on the flywheel. Looks like a successful exercise.
    John.
  • David N.
    • June 30, 1991
    • 142
    My fly wheel
    I looked thru all of my Corvette reference books and could not find a part number corresponding to the one you have. It may be another GM vehichle part.
    David Nims 19639
