1961 Antenna - NCRS Discussion Boards
1961 Antenna
  • Joe D.
    • April 30, 2002
    • 382
    1961 Antenna
    I have a 1961, and I do not know if my antenna is original. The only markings on it is 7-173, it is on the base near the cable conection. It also looks like it is missing a the lower part of the mast. The mast ends about 1 1/2 inches below the cable conection. It has a slot on each side, looks like somthing should be inserted in the bottom of the mast. Thanks for the help, Joe
  • Bill Clupper
    Re: 1961 Antenna
    The '61-62 Judging Guide has a pretty good description of the correct antenna, including the portion below the rear deck (inside the trunk)
