62 ser. # - NCRS Discussion Boards
62 ser. #
  • David H.
    • December 1, 1996
    • 241
    62 ser. #
    Is the serial # pad on a 62 supposed to be painted or not? David
  • Bill W.
    • March 1, 1980
    • 2000
    Re: 62 ser. #
    no paint .
    • Dale Pearman
      Re: 62 ser. #
      Masking the engine for paint was the most distasteful job at Flint. Often, assignment of this job was for punitive purposes. As a result, the painting was NOT uniform from unit to unit. I would estimate that about half the pads were painted at Flint.
      NCRS wants a clean pad in order for broach marks to be discovered. Broach marks were absent from the pad (observed by the naked eye) whenever a fresh bit (cutting edge) was installed in the broach. Recently, at convention, an original engine was judged a restamp because no broach marks were present.
      Dale Pearman
      • David H.
        • December 1, 1996
        • 241
        Re: 62 ser. # on steering column
        What about the SS pad that is spotwelded to the steering column? Paint or not? David
        • Dale Pearman
          NO PAINT *NM*
          • David H.
            • December 1, 1996
            • 241
            Re: NO PAINT
            Thanks for you brain usage. . David
            P.S. Dale go back and look at the steering gear discussion, I found and listed some interesting info that is in the GM service manuals! David
