C1: heater leak - followup - NCRS Discussion Boards
  • Michael Jones
    Re: C1: heater leak - followup
    Once you get the radiator drained down below the level of the heater, the pressboard heat distributor duct removed, and the hoses and power & ground wires disconnected, you'll find four studs protruding into the engine side of the firewall around the heater air inlet box - remove the four nuts and washers and the heater will come out from the inside.
    • ROB DAME MEM# 36211
      Are you sure it's the core leaking
      There is a tool for testing leaks in cooling systems.
      If you don't have one some part stores like Autozone may
      loan you a cooling system pressure tester. It's a hand pump
      with a hose and adapter similar too the radiator cap.
      You hook this up to the radiator and pump it up to about
      15 lbs. Once the pressure is in the system look for leaks.
      After you find the leak release the pressure by removing the
      tester from radiator.You will want to make sure the system
      is full of water before testing.
      This can also be done by filling the cooling system and running
      the engine till it gets warm and biulds up it's own pressure
      but be carefull releasing the pressure cap on a hot engine.
      Don't be surprised if you find a hose or the hot water valve leaking.
      That repair is a lot less work and worth checking out first.
