Re: C1-Rearend Puzzle - NCRS Discussion Boards
  • Gary Chesnut
    Bill, have alot of research info at home on the subject. Easiest way to tell if Corvette rear axle housing or not is the brake backing plate flanges on a Corvette are rotated approximately 45 degrees and on a passenger car the are flat i.e. horizontal with the spring perches.
    Also, have early 58 posi unit somewhere in my pile along with posi axles. Send me an e-mail and I will send you what the axle length measurements should be.
    Good luck, Gary....
