Chambered Exhaust vs. Standard Exhaust - NCRS Discussion Boards
  • Mike McKown
    #31
    Walker
    Now that I think about this, I believe Walker was Chevrolet's source for the side pipes. But I think they independently developed and marketed them before Corvette usage.
      Re: Popping through exhaust with chambered pipes?
      "Popping" on overrun can also be caused by an exhaust leak (allowing air into the system), or by a failed diverter valve diaphragm on an A.I.R. system (allows pump output into manifolds on overrun, which a functioning valve diverts out through the valve's "muffler" on overrun instead). Can also be caused/aggravated by lean idle mixture (throttle plates are closed on overrun, so the idle circuit is feeding mixture under very high vacuum) or by retarded idle timing (inadequate vacuum advance).
      • Mike McKown
        #33
        Very well stated John *NM*
        • Roger Legge
          #34
          Re: Chambered Exhaust vs. Standard Exhaust
          In addition to being offered on a Camaro, I believe it was also offered on the '69 Chevelle.
          Roger
          • Roger Legge
            #35
            I have read that a defective valve in the AIR system can possibly cause a popping sound in the exhaust, but I can't claim this to be 100% true.
            Roger
              Roger -
              Correct - see my post below - the diverter valve is designed so that when the rubber diaphragm fails, the valve defaults to the open position, dumping pump output to the manifolds full-time.
