Drum Brake Assembly Reference? - NCRS Discussion Boards
  • Pete VanSeggern #30920
    Is there a good reference for reassembling drum brakes- where all the springs, etc. go? The AIM doesn't cover that because the entire trailing arm / rear brake assembly ('63) and the entire spindle / front brake assembly were put onto the car as preassembled units. The shop manual (also '63) probably assumes that any mechanic worth his salt will simply reassemble it the way it came apart. It's been four years since I took mine apart, and I've picked up a bunch of the hardware, etc. and I'd just like to get it back together reasonably properly. Thanks.
