66-427/425hp Correct Engine Painting - NCRS Discussion Boards
    I am interested in the "correct" way to paint my engine. What items were on the engine besides the intake, exhaust and possibly the bellhousing.
    I am assuming the engine should be assembled so the gaskets will have to be painted too. Does the waterpump get painted on the engine?
    Are the intake/valvecover/and oilpan gaskets that C/Central sells correct?
    A recommendation on a brand of paint?
    Thanks!
    John
  • Bill Clupper
    Re: 66-427/425hp Correct Engine Painting
    John, If you can borrow or have a copy of "Corvette News" Volume 9 #5, there is a full article from the engine plant on the way the engine was assembled, including a picture of the engine painting line! To answer your question more directly, water pump and exhaust manifolds were on the engine. The intake manifold was covered with a mask. A description of the process is also included. Ihope this helps
