454 Mechanical or hydraulic camshaft?
Re: 454 Mechanical or hydraulic camshaft?
An easy way to confirm is to measure the height of the clearance ramps. They should have a height of about .014" off the base circle and be linear with a velocity of about .0002" per degree of crankshaft rotation, so they should consume about 70 degrees of crank rotation, or about 35 degees at the cam.
Duke- Top
My references show that all camshafts with the 4366 casting number were solid-lifter cams with .520" lift (P/N 3904362 for '67-'68 427/435 and '71 454/425), and the 3144 casting number used for a solid-lifter cam with .520" lift for '66 427/425 (P/N 3863143). Both castings should also have an "OMO" symbol cast-in adjacent to the casting number.- Top
- Top
John- what is different in the 4362 and 3143 cams....everything I have ever seen shows the timing and lift the same, which is the case in Clems's website below. There must have been a reason they altered the casting and part numbers...both have the rear groove in the journal...thx!...Craig- Top
