Now this is probably a dumb question, but here goes. My early 69 (Oct68) needs the rear shelf for the glass. A forum member has one with the rear mounting hinges. I have the handle and what looks like a long hinge attached to the top of the compartment. Here is the question. What size is the correct shelf. I can then decide if the one for sale will work. It seems that the 68 model year was different then 69.Thank youRoger
69 rear glass shelf
Re: 69 rear glass shelf
Roger,
I also have an Oct. '68 coupe and can take measurements for you. What measurements do you need? Length and width? I will get to this this afternoon and report back. I don't remember "a long hinge attached to the top of the compartment". I will verify later. Could you email me with your VIN?
Jeff- Top
Hi Jeffery, Right on the top of the compartment there is something long and looks like there is a pin in the middle. I can grab them and they pull down a little but I don't want to pull to hard. Do I have your email address??Roger,I also have an Oct. '68 coupe and can take measurements for you. What measurements do you need? Length and width? I will get to this this afternoon and report back. I don't remember "a long hinge attached to the top of the compartment". I will verify later. Could you email me with your VIN? Jeff- Top
Hi Roger,
It sounds like you may be looking at the 'flapper' doors and their mechanism which are part of the Astro Ventilation system and thinking they're a hinge. They do have a pivot which allows the doors to move but are separate from the storage shelf.
Alan71 Coupe, 350/270, 4 speed
Chapter Top Flight October 2011- Top
Oh okay that's what I was looking at. Those work with the vents on the rear lid. I need to read up on how that works. What was the thinking from GM. exhaust air flow in the cabin. Are there controls to open and close. Thanks Alan. I guess the shelf and its hardware is independent then.Hi Roger,It sounds like you may be looking at the 'flapper' doors and their mechanism which are part of the Astro Ventilation system and thinking they're a hinge. They do have a pivot which allows the doors to move but are separate from the storage shelf.Regards,Alan- Top
Hi Roger,
The 2 flapper vents were controlled by a vacuum signal from the heater/ defroster controller on the shifter console.
When the black 'wheel' that controls the temperature, H-C, is moved to the C (cold) setting the vacuum actuator (on the flapper door mechanism) opens the doors, and fresh air flows through the interior. The vacuum runs through a long length of copper tubing with a short piece of hose at each end.
This system took the place of the 'vent' windows that disappeared in 1968.
You can see the copper vacuum tube in this picture.Attached Files71 Coupe, 350/270, 4 speed
Roger,
The dimensions of my shelf is:
42 1/2" wide at the front x 20 1/2" deep. This is pretty accurate but may be slightly off since it was measured installeed and it is tight back there (at least it is for us old guys).Also attached is a picture of the hinge area. Hope this helps.
JeffAttached Files- Top
Thanks Jeff it looks like I have at least the metal pieces on the frame that the rear brackets mount to . The person selling the shelf has the rear brackets with it so if the size checks out I will get it. Thanks fo your help and will keep you posted.RogerRoger,The dimensions of my shelf is:42 1/2" wide at the front x 20 1/2" deep. This is pretty accurate but may be slightly off since it was measured installeed and it is tight back there (at least it is for us old guys).Also attached is a picture of the hinge area. Hope this helps.Jeff- Top
