63 Inner Fender Question
Re: 63 Inner Fender Question
I have several 63s here, none with those holes. Not saying it didnt happen, but I dont remember seeing it.
I would need some more pictures of the inner-fender inside and out to tell if it is original.- Top
- Top
- Top
check out that BENDIX power brake unit like I said, it was remote from the firewall and was mounted on the inner fender about where your holes are. On the opposite side was of the holes is there any scarring where a nut plate or washer and a nut might have been? If you can see this then that would to me be an indictation that there was something definetely mounted to that inner fender at one time and not just some holes that were drilled and never used. I have seen a 66 Corvette and a 64 fuelie that both had this remote power brake unit mounted to that inner fender like I said.- Top
Thank you Jimmy. Did you see my photo posted immediately above your last post which shows the inner fender (wheel side) shot showing evidence of some form of plate. Were these Bendix units a factory option or dealer-installed or simply after-market at the time?- Top
