Steering Column harness - NCRS Discussion Boards
  • Enzo C.
    • January 12, 2012
    • 533
    I wanted to know if anybody can tell me or send me a pic of the clip, that holds the wiring turn signal harness at the bottom of the steering column ??? Thanks ..... Sorry the car is a 67
    Enzo Colosimo
    Ncrs Ontario Chapter Chairman 🇨🇦
    ENZ-Z06/67
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: Steering Column harness
    Enzo, what year? There were many variations of the c2"s.
    Rich
    • Bob R.
      • June 30, 2002
      • 1595
      Based on your writing it sounds like you are talking about a 63 and here is a photo of that part.Corvette steering column 006.jpg
      • Russ S.
        • April 30, 1982
        • 2161
        Enzo, Check Corvette Central part number 562181. I think that is what you are asking about.
        • Enzo C.
          • January 12, 2012
          • 533
          Sorry bob I should of mentioned my car is a 67
          Enzo Colosimo
          ENZ-Z06/67
          • Enzo C.
            • January 12, 2012
            • 533
            Hi Rich ,sorry I should of mentioned it is a 67
            Enzo Colosimo
            ENZ-Z06/67
            • Enzo C.
              • January 12, 2012
              • 533
              Hi Russ, I should of mentined my car is a 67. The part you have listed is for 64-66
              Enzo Colosimo
              ENZ-Z06/67
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11302
                Anything in these photos of a '67? Do you have a part # from the AIM for reference?
                This one?
                • Enzo C.
                  • January 12, 2012
                  • 533
                  Hi Rich,
                  Are these 67 column pics ??? they look different
                  Enzo Colosimo
                  ENZ-Z06/67
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11302
                    Originally posted by Enzo Colosimo (54308)
                    Hi Rich,
                    Yes, a November built '67. However it is without the plastic cover which wraps around the mesh. The steering column changed later in the model year, and also the optional tele-column was available. But the clip for the signal harness connector remained the same as far as I recall. I did a little research for you. That clip is part of the Main Dash Forward harness. It is part of the mating connector for the turn signal switch harness in the main harness. You can see the connector in your 1967 AIM UPC 12 Sheet B3. note....."HARNESS CONN (Clip to bracket)".
                    Are you actually missing the clip, which attaches to the brake/clutch pedal support? I have a March built '67 in the shop and just took a few more photos for you. This one has a Tele column, but the connectors and clip are the same as the earlier car in the previous photos.
                    1st photo shows it attached to the pedal bracket.
                    I looked at several suppliers and came up empty.
                    It is possible that you may find it through the 2 harness suppliers. Lectric Limited or M & H. (note these are links to them) Check there or call them. Another option is to find someone who just replaced their Main harness and see if they'll get you the clip.
                    Rich
                    • Enzo C.
                      • January 12, 2012
                      • 533
                      Great pics Rich, now I see what I am missing... the search is on... let me know , thanks
                      Enzo Colosimo
                      ENZ-Z06/67
                      • Leif A.
                        • August 31, 1997
                        • 3607
                        [ATTACH=CONFIG]56954[/ATTACH][ATTACH=CONFIG]56953[/ATTACH]
                        This one?
                        [ATTACH=CONFIG]56956[/ATTACH]
                        Rich,
                        Your pictures and advice are always so detailed and spot on...thank you!! Now, can you tell me what year, make and model that clutch pedal pad is for??
                        Leif
                        • Enzo C.
                          • January 12, 2012
                          • 533
                          Leif, I believe the brake pedal is C2 and the clutch is for a C3 in my opinion ???
                          Enzo Colosimo
                          ENZ-Z06/67
                          • Richard M.
                            Super Moderator
                            • August 31, 1988
                            • 11302
                            Good catch......I think it was some non-Corvette pad, maybe Chevelle or something, not really sure. That one in the above pics had those vertical ribs.
                            This is 68-79 Corvette
                            I think I changed it to one of these. But the car is in Norway now so I'll have to check with the owner. I'm pretty sure I did.
                            If I didn't, I'll have to get one for him.
                            Rich
                            • Leif A.
                              • August 31, 1997
                              • 3607
                              [ATTACH=CONFIG]56984[/ATTACH]
                              [ATTACH=CONFIG]56985[/ATTACH]
                              Rich
                              Rich,
                              Probably the only reason I noticed it is I had a similar one on my '67 when it was judged in October...Ara Gechijian (48542) who did my interior judging "busted" me for an incorrect pad which I have since replaced with one like your second picture. Happy New Year to all!!
                              Leif
