Re: Distributor Main Shaft Drive Gear(s)
This is a common issue on performance modified engines. The nitrided cam surfaces is also on it's rear gear teeth. It forms a nice hard wear resistance on the lobes but not good for iron distributor gears as you point out. The steel being harder surface should end that issue for you. It is important to have materials and hardnesses that "play well together". Engineering wise on a 90 degree helical gear set the softer material should be on the driver and if harder than it should be on the driven with constant lubrication.
The 58 pound pump I would assume increases the load on the gearing too. Stock oil pumps are more like 40 lbs at cruise speeds.
Glad you got that solved so the wheels can keep on a rolling..........
