Spindle Inspection Markings - NCRS Discussion Boards
  • Rob M.
    • April 30, 2003
    • 657
    Question,
    I am wondering if anyone else has seen inspection paint on spindles other than the red/orange paint called out in the TIM&JG? Here is what I found when I pulled the front suspension off my May 6th, 66 car. Blue on one side and white on the other.
    When it was recently judged, the chassis judge had issue with it and told me it "wasn't typical."
    Rob
    '66 327/300 Regional Top Flt
    '08 6 speed coupe
  • Mike M.
    • May 31, 1974
    • 8365
    Re: Spindle Inspection Markings
    i believe they are typical. have done numerious c-2's and have found inspection paint markings other than the orange(which all tended to have). mike
    • Jim D.
      • 2882
      On my April 65 car - both sides - the lower ears had dark green paint on them. Both sides - above the spindle, on the outside was a green daub and an orange hash mark. One side only, above the spindle on the inside was a white hash mark.
      • Rob M.
        • April 30, 2003
        • 657
        Thank you both for your replies ...
        Rob
        '08 6 speed coupe
        • Jimmy G.
          • November 1, 1979
          • 975
          Mike and othwers
          How do you do the orange on the spindles?? Buy a quart of orange paint and dip them to about 3 inches on each end?? If so who makes a correct color paint..
          • Jim D.
            • 2882
            The orange on my spindles was a single hash mark approx. 1/2" wide and 2" long. It looked like it was done with a small brush, certainly not dipped.
            • Bill W.
              • March 1, 1980
              • 2000
              Jimmy I was told years ago that the amount of orange on the spindles depended on how full the paint container was . My 65 was completely covered in orange .DSC_1434.jpgDSC_1433.jpgDSC_1431.jpgDSC_1417.jpg
              • Jim D.
                • 2882
                • Brian K.
                  • May 31, 2004
                  • 358
                  My March 4th 1966 built roadster has blue and white inspection marks on the spindles.
                  • Rob M.
                    • April 30, 2003
                    • 657
                    Brian,
                    Do you happen to have a photo of them?
                    Rob
                    '08 6 speed coupe
                    • Jim D.
                      • 2882
                      With all the different colors and formats that have been shown on known original cars, I think it's safe to say that nothing should be considered "typical" and these marks shouldn't be judged or even commented on.
                      Here's a pic. showing green on mine where Rob's is blue and white.
                      • Gary C.
                        Administrator
                        • October 1, 1982
                        • 17549
                        Guys,
                        Colors are mostly used as "Parts Identification" paint marks. Very few are "Inspection" paint marks.
                        Inspection paint mark of a thin swipe of robins egg blue on the rear pinion nut indicates the nut was properly torqued. That's an inspection paint mark.
                        Gary
                        NCRS Texas Chapter
                        https://www.ncrstexas.org/
                        • Rob M.
                          • April 30, 2003
                          • 657
                          Agreed, and thanks for the clarification. Mine had yellow "daubs" on the nuts which I copied too.
                          Rob
                          '08 6 speed coupe
                          • Matthew G.
                            Infrequent User
                            • October 13, 2012
                            • 24
                            Rob,
                            Here are the original spindle markings on Kathy's 66. Aside from me cleaning them during this photo, I don't think they've ever been messed with. Blue (almost purple) on the top inward portion.
                            • Brian K.
                              • May 31, 2004
                              • 358
                              I sent you an email about you picture request.
