1962 Power Top - NCRS Discussion Boards
1962 Power Top
  • Joel M.
    • May 31, 1975
    • 141
    1962 Power Top
    Referencing the new 61/62 JG page 58 stating the trunk mat should be installed under the bottom edge of the division panel on power top models. There is not sufficient space between the trunk floor and the liner to accomodate a mat. In addition , the two screws thru the vertical face just over the tire well sandwich things in a manner that does not allow a mat to be installed. What am I missing ? Or better yet where do I cut? ------ Regards/ Joel Miller
  • Loren L.
    • April 30, 1976
    • 4104
    Re: 1962 Power Top
    If you'd keep on working of the Jaguar, these little problems would not come up............
    • Joel M.
      • May 31, 1975
      • 141
      Re: 1962 Power Top
      Was looking for a little break from the 120 so I decided to finish up the 62 that has been sitting for ten or so years. Power top works great but I must be missing something on this trunk liner and mat deal. Sure wish I had a good photo of this installation. By the way, I HAVE replaced the radiator since you were by 8/10 years ago. -------Regards/Joel
