Re: 70 L-46 drivability issues
I think at this point it's a good idea to verify TDC with a piston stop, don't do this test with the starter, just turn the motor with your hand.
If you place the #1 cylinder at TDC and the distributor rotor is not pointed at #1 on the cap the chain is suspect. If it's aligned OK but the damper mark is off then the balancer has moved.
