Directional Wire Protector - NCRS Discussion Boards
  • Walter R.
    • January 6, 2009
    • 269
    I am attempting to install new directional wire protector. What is the secret to get the wire into the protector without splitting protector or damaging wires.
  • Walter R.
    • January 6, 2009
    • 269
    Re: Directional Wire Protector
    Has anyone done this successfully?
    • Alan D.
      • January 1, 2005
      • 2027
      I replaced my column and at that time did the protector, so are you trying to do with column installed?
      • Walter R.
        • January 6, 2009
        • 269
        No I have the column out but getting harness in the protector isn't the easiest thing I have done, not that anything is on a C2. The harness is seven wires and getting it in the protector is a task. I will get it done but I was hoping there was a method to the process.
        • Gene M.
          • April 1, 1985
          • 4232
          Walter,
          Take a photo of the connector and wire positions. Remove the wires from the plastic connector housing. The connector prongs can be released from housing with a jewelers screw driver. Slide wires thru protector and re install plastic connector following your photo for correct wire position.
