C2 Heat riser question - NCRS Discussion Boards
  • Hector G.
    • November 1, 2004
    • 234
    Which one of these two 2 1/2 heat riser valves is closer to factory configuration for 67 BB?
    The unused valve came out of the GM box.
    Thanks for your help.
  • Gene M.
    • April 1, 1985
    • 4232
    Re: C2 Heat riser question
    Hector,
    Just going by memory and not going out to garage to look the one on the left in the first picture looks like a big 2 1/2" manifold outlet small block valve.
    • Stephen L.
      • May 31, 1984
      • 3148
      Hector, The valve counterweight shaft should face forward with the weight facing the engine. The "flat" side of the valve mates with the manifold. The correct part is #3887034. Your new one is correct for BB and HP 327 engines. Don't know what the used one is for.......
      • Hector G.
        • November 1, 2004
        • 234
        Thanks Gene and Stephen.
