1963 silly question - NCRS Discussion Boards
1963 silly question
  • Frank D.
    • December 27, 2007
    • 2703
    1963 silly question
    OK - having a disagreement with a buddy about which way the 63 coupe dome light lens faces - he says mine is backwards but I did it like "thought" the AIM showed. Some pics would be nice...
  • Harry S.
    • July 31, 2002
    • 5258
    Re: 1963 silly question
    The gradual slope is aft. Tried taking a picture but didn't work. I'll post it anyway. It needs to be rotated.
    • Jim D.
      • 2882
      Tapered edge forward if 63 is the same as the rest of the mid-years.
      • Frank D.
        • December 27, 2007
        • 2703
        In that case; it looks like I'm right for a change !
        • Stuart F.
          • August 31, 1996
          • 4676
          Frank;
          Looks like you got one each reply. Which one did you choose?
          Stu Fox
          • Frank D.
            • December 27, 2007
            • 2703
            Neither yet - I'm so confused!
            • Harry S.
              • July 31, 2002
              • 5258
              I think Jim and I said he same thing?
              • Jim D.
                • 2882
                My reply was based on examples of untouched originals and the 1965 Judging Guide. What does the 1963 JG say?
                • Harry S.
                  • July 31, 2002
                  • 5258
                  "Taper Facing Rearward" I said gradual slope, I guess that means taper.
                  • Frank D.
                    • December 27, 2007
                    • 2703
                    The JG says "taper facing rearward" -- I took that to mean that the side with the more gradual slope faces the split. A bunch of cars I've looked at have it opposite... Pics of my lens and how its positioned; inside and outside the car...
                    • Harry S.
                      • July 31, 2002
                      • 5258
                      I agree with you.
                      • Frank D.
                        • December 27, 2007
                        • 2703
                        That's what I think unless someone knows differently. I'm running through the JG prior to Lakeland and boy the stuff I've had to monkey with.
                        Sometime I'll tell you the shenanigans I went through to get the cigarette lighter to pop out correctly ?!?!#$
                        • Tim T.
                          • December 9, 2009
                          • 141
                          Frank,
                          Mine judged fine at the KC nationals with the slope or taper facing rearward.
                          Tim
                          • Loren L.
                            • April 30, 1976
                            • 4104
                            The only way that the supervisor/inspector "on the line" was going to give a ____ was if it did NOT have a lens.
                            • Jim D.
                              • 2882
                              Originally posted by Frank Dreano (48332)
                              The JG says "taper facing rearward" -.
                              That's the opposite of 1965 JG.
