1967 Fuse panel Fuse Colors - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    This is the 1967 Fuse Panel. Top to bottom.
    10A BU Lps/Gages
    25A Heater
    10A Radio
    4A Panel Lps
    20A Tail/Stop
    20A Cig Ltr/Hazard
    Since it was loaded with 5 fuses and part of the harness assembly, the fuses are not AIM'd separately. Just the lower 20A (106653), clear, gets installed after the lower screw is installed.
    Archives not telling me any colors, so I found that elsewhere, except the 4A.
    What color is the 4 A fuse? (EDIT....NEVER MIND. JG says 4A is Pink.)
    Loaded total
    2 10A Red
    1 25A White
    1 4A Pink
    2 20A Clear
    ps I'll just leave this here for the next guy.
  • Keith B.
    • September 15, 2014
    • 1575
    Re: 1967 Fuse panel Fuse Colors
    That is true for a heater only cars. RPO C60 A/C got a 30 amp fuse for the heater. Not sure on color
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11302
      Yes agreed, 1967 AIM UPC C60 Page E1 Item 7 Part# 120114 is a Fuse AGC 30A.
      My data states Green.
      AIM Item notes:
      120114 Fuse - Insert in Fuse Panel receptacle marked "HEAT - AIR-COND"
      • Peter L.
        • May 31, 1983
        • 1930
        It is interesting to note that FUSE "call out" on UPC C60; SHEET E1 (DWR DATE 5-23-66/REL 5-24) in the 1967 CORVETTE AIM I have lists
        p/n 129114 & this is the p/n for the 1.250" 30A (3AG or AGC) fuse on some FUSE information I have & it does not list a COLOR CODE. In addition, p/n 129114 is the FUSE part number call out in the C60 section of the 1964 thru 1966 CORVETTE AIMs as well as the 1967 CORVETTE AIM. FUSE p/n 9426331 is the 1.250" 30A (3AG or AGC) fuse that has the COLOR CODE which is listed as "GRN LT."
        As with other things, it might have taken some time for the 30A color coded fuses to make it into the 1967 CORVETTE PRODUCTION line. Pete
        • Donald O.
          • May 31, 1990
          • 1580
          Peter,
          Aren't the color stripes on the inside of the glass and not painted on the outside?
          Don
          The light at the end of the tunnel has been turned off.
          • Keith B.
            • 1575
            Originally posted by Donald Olson (17357)
            Peter,
            Don
            Correct originals I have seen the paint is on the inside where as the repros are outside
            • Peter L.
              • May 31, 1983
              • 1930
              Don - As Keith has noted the colored strip or band we find on 67 FUSES is usually on the inside of the glass tube at least for the 1.250" fuses & the DIM. MIN. of the stripe is .100". As long as we're on the subject, the shorter fuses like the 0.625" fuse 5A (1AG or AGA) INST LPS FUSE used on C3s can have a 0.030" TAN stripe according to the FUSE info but the 5A FUSEs made by BUSS that I have seen have "dap" of TAN paint on the outside of the glass. Also NOTES on the FUSE info read as follows
              1. OPTIONAL CONSTRUCTION - COLOR CODE MAY APPEAR ON THE ELEMENT.
              2. (*) FOR .625 FUSE LENGTHS, A .12 MIN DIA IDENTIFYING DOT MAY BE USED OPTIONALLY IN LIEU OF A STRIPE.
              Pete
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11302
                Last week while researching, I read that the band could be either side. See post #21 by John Hinckley.
                https://www.forums.ncrs.org/showthre...use+1967+color
                Here are 2 original fuses removed from this '67. Color bands are inside.
                Edit.....Vinnie Peters just sent me 3 Restorer articles in PDF for our viewing pleasure. Thanks Vinnie !!!
                1-Summer 1993
                2-Winter 1997
                3-Winter 2003
                  • 15573
                  [ATTACH=CONFIG]67487[/ATTACH][ATTACH=CONFIG]67485[/ATTACH][ATTACH=CONFIG]67486[/ATTACH]
                  1-Summer 1993
                  2-Winter 1997
                  3-Winter 2003
                  The Winter 2003 issue of The Restorer had color pictures of four original Corvette fuse blocks on the back page. It was the only way we had to get color images in the magazine back in those days.
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11302
                    Terry, I remember that color backpage. Boy I'd love to get myself one of those 1050810 fuse kits. I never saw one in person.
                    However, I just happen to run across my own little recent fuse kit acquisition......
                    NOS, 3 complete '67 sets(non C60), from my deceased best friend Chuck's buddy and past co-worker, "Corvette Enthusiast" Extraordinaire & friend of mine. I have one set for the '67 I'm on and 2 sets for another Corvette buddy of mine down here in FL. I just got them yesterday in the mail. Please do not ask what we paid for them.
                    All are colored inside.
                    Pinks and Reds
                    Clears and whites
