Re: Help with camshaft selection for 350 SB
What you say is true, but those are aftermarket flat tappet cams with aggressive profiles that require much higher spring force than OE. The name Comp Cams comes to mind, especially the XE series. I have consulted with dozens of vintage Corvette owners on engine restoration, and I don't recall any who ever experienced any cam problems IF they followed my advice to use a Federal Mogul manufactured OE replacement cam, OE replacement valve springs, and CJ-4 oil.
If anyone looking at this thread with a F-M OE replacement cam using OE equivalent replacement valve springs has ever had a wiped lobe problem or knows some who has please chime in. And remember, only a F-M manufactured OE replacement cam and OE equivalent valve springs. Aftermarket cams with gorilla valve springs don't count.
Don't drink the Kool-Aid, Mike.
