Is the correct number 095 or 096? Thanks in advance
1963 delco headlight switch part number
- Top
Re: 1963 delco headlight switch part number
Joe, Do you know if the plastic housing colors are the same? I was thinking that was one way to tell the difference??New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Here's a couple of pics of the 63 repo switch. You be the judge!
JRAttached Files- Top
Joe, I think the white plastic end is Yellow on the 63 switch and on the 096 switch its as your pic (White).This switch as your pic surely functions the same, But what I have seen is the rheostat sometimes will not get the dash lights as bright as they need to be, I recently ran into this with a friends 63, took a measurement of my switch and his and the voltage was less than the original. this could be a problem on a PV or operations. His lights at full brightness was not as bright as my car at night.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
I found this picture on the internet.Attached FilesNew England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Here is my original 63 switch, I Feel this is not 50 years of yellowing. and is more yellow than an actually yellowed white. which I have seen before when the elements come into play.Attached FilesNew England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Edward------
A difference in the color of the insulator could not account for the difference in part numbers for the '095' and '096' switches. There would have to be some functional difference. The voltage difference you mention could be such a difference, though.
Also, GM never replaced the '095' switch with the '096'. The '095' was simply discontinued without supersession while the '096' remained available for many years. This strongly implies that GM did not consider the '096' to be a suitable replacement for the '095'. The aftermarket appears to be not so discerning.In Appreciation of John Hinckley- Top
Joe, I am just stating that the 095 switch has a yellow plastic end on my 63 and as you eluded to the difference I found with the voltage difference
for dash lights. as for the 096 switch may have differed in some way but I am not sure. If the dash light bulbs changed then there might be the answer, but highly doubt it. or maybe the dash light brightness was to much on 63 ??New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
