This switch failed with a open on the IGN-2 terminal during START. IGN-2 is the Coil+ source during Crank to supply full battery voltage.
Using a few tools I carefully bent the 4 tabs outward to remove the innards of the switch, cleaned the dirty contacts, reassembled loosely, tested good, then reassembled and bent the 4 tabs back in place.
Photo sequence for reference.....
Rich
Rich
Pete
