63 Ash Tray Door Knobs
Re: 63 Ash Tray Door Knobs
Smooth. 110293
- Top
Jace, the knobs are peened over on the under side, generally you drill or dremel tool and grid away carefully. you will need to remove console.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
I did a small modification to a new ash tray door knob (purchased from Paragon) for my '64 which allows me to remove the chrome knob without destroying the two nipples. Actually, I replaced the nipples with threaded screws - now, if I remove the console I can remove 2 small screws and reuse the same handle. I wrote a short (not all that technical) tech article for the MAC Signal Seeker a while ago - copy attached, along with 2 pictures.Ed- Top
Rear of door one screw crew and a couple of weal Ali rivetsAttached Files- Top
