Rear Caliper Steel Lines routing - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    Did the factory install the steel lines so that the caliper mounting bolts were accessible with a socket? Were the lines run basically under and just behind the mounting bolts?
    The replacement lines I have fit perfectly except that they block access to the caliper mounting bolts.
    Bill
    • 6940
    Re: Rear Caliper Steel Lines routing
    Bill, You may have to tweak the lines some, the replacement lines on my 72 I had the same thing. The bolts where accessible from the factory.
      Bill
      Bill------
      I can tell you for certain that the brake lines interfered with access to the caliper mounting bolts on my 1969 which should be the same as 70-72. However, it is possible to re-position the lines slightly to gain access to the bolts.
      • Bill L.
        • February 1, 2004
        • 1403
        Thank you Joe,
        It has been several years since I removed the old lines. You confirmed my recollection. I am guessing the factory was not too concerned since they likely installed the caliper before the brake lines with the system dry.
        Kind Regards,
        Bill
        Bill------
        • Bill L.
          • February 1, 2004
          • 1403
          Thank you Edward.
          My recollection jibes with Joe.
          Kind Regards,
          Bill
