Hi folks. I have 500 miles on my car since back on the road. I have Joe Gibbs break-in oil in it. The rings have seated as there is no smoke what so ever. Hoe long would you run this oil till the first oil change? My machinist said it wouldn't hurt him to see 3000 mile on it. Seems a bit high to me but I'm not sure. What do you folks think. Thanks as usual. Guy.
1954 break in oil question
Re: 1954 break in oil question
According to the manufacturer, you're already overdue.
I'd read Duke's articles on what to use from now on and see what's on sale today at Wally World that fits the bill.- Top
One of the main reasons for break in oil is ZDDP - Zinc dialkyldithiophosphate
Cam lobes and flat tappet lifters are crucial to break in during the first couple minutes of starting
The 235 has such weak spring rates it is not as a huge concern as it is with say a L88
Never the less - if you have broken in the motor - I would change the oil
Me personally I use Shell Rotella with a bottle of ZDDP.
Plus remember there is no filter on the 235's so any break in particles are floating around
You would want to drain those.1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
1957 Corvette - FI 3 sp - Black and Silver- Top
Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
Modern CJ4 oils have far more ZDDP that the oils of the 1950s so straight out of the bottle is already overkill.- Top
Chris,
The text above mentions using API SN oils. They have nowhere near the ZDDP levels contained in CJ4 which is what is being discussed here.
BTW, If you're going to plagiarize someone's else work, at least give them credit.
- Top
Current C-category oils have a P limitation of 1200 ppm and most spec-out in the range of 1100-1200, which is about what S-category oils had before SL went to 1000 and SM/SN to 800. In fact, prior to the first S-category P limitation most of those oils were dual rated for both S and C-category service.
More than about 1400 ppm P over the long run can lead to some exotic corrosion mechanisms, which is why it's not a good idea to add extra ZDDP to C-category except for break-in.
For the umpteenth time I've attached the oil article. If you have not previously read it, now is a good time, and remember, I'm not trying to sell you anything... just providing the facts that should enable anyone to make the most economical purchase.
DukeAttached Files- Top
