Database of Restoration Documents
This is a sticky topic.
Re: Database of Restoration Documents
Update PageThis page will be used as a placeholder for new files as they become available.
Updated 10/16/2024
Eventually these new files will be integrated into the Main Page list and its associated downloadable pdf list.
NOTE: Latest additions at the bottom of this table.
Rich
Keywords "C" gen Database of Restoration Update Documents Links Add Date Author or Contributor Windshield/Sideglass/Vent C2 LOF Glass - Corvette Replacement Manual (Aug 1966).pdf 9/3/2020 Jack Morocco Bulkhead/Firewall Connector Repair C2 Replacing Housing F. Dreano mod.pdf 10/14/2020 Frank Dreano Water Pump Rebuild - Reproduction Kits C1,2,3 Water Pump Rebuilds using Reproduction Rebuild Kits - Rich M-2.pdf 10/14/2020 Rich Mozzetta C6 Automatic Shifter Issues C6 Auto Shifter Stuck in Park or Unable to Get back to Park-r.pdf 11/29/2020 CF 4SUMERZ C2 Headlight Motor Diagnosis & Repair C2 C2 Headlight Motor Diagnosis 11-15-20.pdf 12/19/2020 Rich Mozzetta
(PDF by Dave Zuberer)C2 Ground Straps & Hardware C2 C2 Radio Ground Table v 3-3.pdf (archived) 12/21/2020 Alan Drake/Gary Beaupre/Rich Mozzetta(a little bit) C2 Ground Straps & Hardware C2 Radio Grounds MRF 1-18 9am .pdf 1/23/2021 Alan Drake/Gary Beaupre - Edited by Mark Francis Horn Repair C1 1959_9000352_Horn rebuild.pdf 2/13/2021 Rich Mozzetta/PDF by Dave Zuberer Steering Column - Telescopic C2 1967 Tele Steering column rebuild.pdf 2/13/2021 Rich Mozzetta/PDF by Dave Zuberer C2 Ground Strap Related & More Hardware Details C2 GM Hardware Descriptions+OCR.pdf 2/15/2021 Alan Drake - (Partial file due to Alan's PC Crash - To be updated later) Restored/Resurrected by Jack Morroco :-) Steering Column Blueprints C2,C3 See this Post HERE for the PDF files 4/19/2021 Saginaw - From NCRS Archive Database (Bill Sangrey) Steering Column Rebuild 1964,1965,1966 C2 A process to rebuild a standard steering column.pdf 9/7/2021 Rich Mozzetta/PDF by Dave Zuberer and additional details Steering Wheel Restoration 1956-1962 C1 1956 to 1962 Steering Wheel Restored.pdf 9/7/2021 Rich Mozzetta/PDF by Dave Zuberer Steering Column Rebuild 1964,1965,1966 C2 1964 -1966 Standard Steering Column Rebuild.pdf 9/7/2021 Ed Szeliga - PDF from Aug 2016 thread C2 Door Anatomy Update C2 Corvette Door Anatomy Mod 9-22-14 DZ.pdf 10/8/2021 Dave Zuberer - Update from earlier version on Main Page. Also See THIS THREAD C1 Front Park Brake Cable C1 C1 Corvette Forward Parking Brake Cable Replacement.pdf 10/19/2021 Dave Zuberer - ST-12 Service Manual missing a important step to replace the cable. C3 Seat Cover Restoration C3 SeatcoverRebuild (1).pdf 3/4/2022 Patrick Boyd (Author - Charley Manker, TN ) Service News - 1957 Wiper Motors C1 Chev Svc News Vol 28 No 12 Dec1956.pdf 3/4/2022 Gary Chesnut (Author - Chevrolet) Service News - 1956 Wiper Motors C1 Chev Svc News Vol 28 No5_May 1956.pdf 3/4/2022 Gary Chesnut (Author - Chevrolet) 1963-1982 HD Rear Spring Data C2/C3 1963_1982_HD_Rear_Springs.jpg 11/29/2022 Gary Beaupre & Joe Lucia Oil Canister Rebuild C1/C2 Oil Canister Rebuild.pdf 1/14/2023 Online via Harry Sadlock Instrument Cluster C2 Wiring and Bench Testing the Mid-Year Corvette Instrument Cluster - Zuberer & Welsh - rev 2-27-1.pdf 3/27/2023 Compressed version to fit here Dash Related Connections C2 Mid-Year Corvette 'Non-Cluster' Dash Connections Zuberer-Welsh 5-19-16 FINAL - online mod.pdf 3/27/2023 Compressed version to fit here Torque Data Allied Systems Torque Charts.pdf 4/21/2023 Dan Dillingham - Ref Thread HERE Torque Data Wagner torque charts.pdf 4/21/2023 Dan Dillingham " Anti-Seize Info anti-seize technology.pdf 4/21/2023 Dan Dillingham " Bolt Grade Chart - GM to SAE ALL Bolt Grade Chart.jpg 7/2/2023 Gary Beaupre Carburetor - Carter AFB Docs C1,C2 Carter AFB Specs and Parts.pdf
Carter AFB Jets and Rods.pdf
7/6/2023
7/9/2023Duke Williams - Ref Thread HERE
Edited and converted to OCR format to enable search function - Jack M.
Keep search strings short for best results.Headlight Switch Repair C1, C2 similar Headlight_Switch_Repair_Rev2.2.pdf 7/10/2023 Rich Mozzetta - DOCX by Ed Szeliga PDF Edited and reworked to fit Jack M. Water Pump Rebuild C1,2,3 Small Block Water Pump Rebuild-DennyWilliams.pdf 7/10/2023 1997 version - Ed Szeliga reworked to fit. Mike Hunt 1956 & 1957 Survey Data & "V" vin numbers C1 See Post #78 for the files 7/10/2023 By Mike Hunt - Acquired on Public website many years ago 1965, 1966 Tele Column Notes C2 1966 Tele Steering Wheel & Column Removal.pdf 2/20/2024 From 1966 Chevrolet Service Manual John Hinckley Memoirs
(A MUST READ)MISC JohnHinckleymemoir.pdf 3/7/2024 From Duke Williams thread HERE Distributor Applications ALL Link to thread HERE 10/16/2024 From Rich M. - Written by Alan Colvin Attached Files- LOF Glass - Corvette Replacement Manual (Aug 1966).pdf (2.28 MB, 110 views)
- Water Pump Rebuilds using Reproduction Rebuild Kits - Rich M-2.pdf (715.7 KB, 14 views)
- Auto Shifter Stuck in Park or Unable to Get back to Park-r.pdf (1.58 MB, 30 views)
- 1953-1962 3rd-Arm Bearing Puller - Rich Mozzetta.pdf (225.2 KB, 4 views)
- C1 Corvette Forward Parking Brake Cable Replacement.pdf (2.30 MB, 20 views)
- Top
Re: Database of Restoration Documents - P&A Standard Parts & Hardware JPGs & PDFs
Here is a group of 24 Standard Parts & Hardware pages scanned as JPG and also PDF files from a P&A Catalog dated May 1, 1966. (Ref thread how I got this info HERE). I'll be adding the files to the Update Page and the Main page eventually.
Note the JPGs are in view below but the PDFs are attached at the bottom of this Post. You can download and print them to make your own copies. I made the PDFs a good resolution size to be clear views and can be enlarged on your computer. Unfortunately the large JPGs I uploaded got reduced in size so not too clear. Best to Download the PDFs. One Caveat..... You'll have to download the PDFs one file at a time..... BUT......
EDIT: Now attached is a single PDF with ALL pages in ONE FILE, and it is Searchable too!
Special thanks to "..you know who you are!"
See the file below....P&A Standard Parts & Hardware.pdf at the very last line in the attachments below.
Note: If you just want to view the JPG images you can enlarge them in your browser by using the magnify Ctrl function. Type Ctrl + several times to magnify the entire screen, Ctrl - to reduce. Ctrl 0 (zero)back to normal.
Note these parts are not all necessarily exactly what was used on the factory floor so use discretion when researching for your restoration tasks. It should be used for reference only but may help identify certain things like bolt and screw types, etc.
Rich
PA_Std_Parts_5-1-1966_0001.jpgPA_Std_Parts_5-1-1966_0002.jpgPA_Std_Parts_5-1-1966_0003.jpgPA_Std_Parts_5-1-1966_0004.jpgPA_Std_Parts_5-1-1966_0005.jpgPA_Std_Parts_5-1-1966_0006.jpgPA_Std_Parts_5-1-1966_0007.jpgPA_Std_Parts_5-1-1966_0008.jpgPA_Std_Parts_5-1-1966_0009.jpgPA_Std_Parts_5-1-1966_0010.jpgPA_Std_Parts_5-1-1966_0011.jpgPA_Std_Parts_5-1-1966_0012.jpgPA_Std_Parts_5-1-1966_0013.jpgPA_Std_Parts_5-1-1966_0014.jpgPA_Std_Parts_5-1-1966_0015.jpgPA_Std_Parts_5-1-1966_0016.jpgPA_Std_Parts_5-1-1966_0017.jpgPA_Std_Parts_5-1-1966_0018.jpgPA_Std_Parts_5-1-1966_0019.jpgPA_Std_Parts_5-1-1966_0020.jpgPA_Std_Parts_5-1-1966_0021.jpgPA_Std_Parts_5-1-1966_0022.jpgPA_Std_Parts_5-1-1966_0023.jpgPA_Std_Parts_5-1-1966_0024.jpgAttached Files- PA_Std_Parts_5-1-1966_0001.pdf (1.25 MB, 28 views)
- Top
Re: Database of Restoration Documents - Standard Parts & Hardware JPG images
Thank you for your contribution.- Top
Steven: You have a list of all the things to do (on a '65) before putting the body back on the chassis? I am keeping track of what I do prior, on a '65 coupe project.https://MichiganNCRS.org
Michigan Chapter
Tom Dingman- Top
The last file in the list of pages for the Standard Parts and Hardware catalog contains all 24 pages as one file. Thank you to all who made this happen.Bill Strobel
Owner Independent Towing
Fayetteville, NC
1979 Corvette White/Red L-82 4 spd
Only 4,200 miles
Do It Right or Don't Do It At All- Top
See below....
Gary, What file are you referring to?
Someone sent me the new HW Pages pdf yesterday afternoon after combining all 24 pages and compressing to get within TDB upload limits(2.86MB pdf). I updated the post(#63) last night and added it to the list and added better notes just a bit ago.
Rich- Top
Thank you. BunkyByrd@gmail.com- Top
Updated C2 Radio Ground Straps and Hardware documentation in the UPDATE PAGE.
SPECIAL thanks to Alan Drake, the Primary Author of this document, along with extensive technical help from Gary Beaupre. These 2 guys had me on their CC list and we all traded scores of emails over the last few months with much research and technical data. Thanks Guys!
Also, special thanks to Mark Francis and Jack Morocco for their expertise with file translations, software edits, and overall technical knowhow.
It's folks like this that are making this a great place to learn and share.
Rich- Top
Adding Wonderbar Schematics here temporarily. At a later time I'll get them converted to PDF for ease of access.
They cover 987730 Chevrolet 3748611 Corvette Radios. Later C1 radio models similar except case configuration, component locations, etc.
1st group is jpg. 2nd group is gif. There is useful information in both.
This Thread may be able to use them to help diagnose the problem.
To save locally, print, etc, Right Click image page, then left click "Save as"(or other command based on browser being used).
- Top
There is also information on the above and other Delco Vette radios here;
Delco 3748611 Corvette Car Radio United Motors Service Delco, build 1958–1960, 7 pictures, 9 schematics, 5 tubes, 1 semiconductors, United States of
Delco 987730 Chevrolet Car Radio United Motors Service Delco, build 1958 ?, 1 pictures, 9 schematics, 5 tubes, 1 semiconductors, United States of America
Also other Corvette Radios here;
Delco 7303211 Corvette Car Radio United Motors Service Delco, build 1972, 4 pictures, United States of America , schematics, tubes, semiconductors, Car Radio
Delco 985396 Corvette Car Radio United Motors Service Delco, build 1963, 12 pictures, 3 schematics, 1 tubes, 5 semiconductors, United States of America
Delco 985686 Corvette Car Radio United Motors Service Delco, build 1963, 4 pictures, 2 schematics, 9 semiconductors, United States of America , tubes, Car
985686 Corvette Car Radio United Motors Service Delco, build 1963, 1 schematics, 9 semiconductors, United States of America , pictures, tubes, Car Radio
Delco 985383 Corvette Radio United Motors Service Delco, build 1962, 1 pictures, 5 tubes, 1 semiconductors, United States of America , schematics, Broadcast
Delco 985921 Corvette Radio United Motors Service Delco, build 1964, 3 schematics, 10 semiconductors, United States of America , pictures, tubes, Broadcast
Delco 7937571 Corvette Car Radio United Motors Service Delco, build 1973, 6 pictures, 1 schematics, United States of America , tubes, semiconductors, Car
Delco 9344661 Corvette 41YFM2 Radio United Motors Service Delco, build 1974, 5 pictures, United States of America , schematics, tubes, semiconductors
Delco 3706551 Corvette Car Radio United Motors Service Delco, build 1953/1954, 1 pictures, 6 schematics, 9 tubes, United States of America , semiconductors
Chevrolet 3711897 Corvette Car Radio United Motors Service Delco, build 1955/1956, 1 pictures, 5 schematics, 9 tubes, United States of America
https://www.radiomuseum.org/r/united...e_81yfmt1.html
https://www.radiomuseum.org/r/chevrolet_3711897.html
https://www.radiomuseum.org/r/chevro...t_3725156.html- Top
