C1 voltage regulator replacement max amperage - NCRS Discussion Boards
  • Al R.
    • June 30, 1988
    • 687
    Re: C1 voltage regulator replacement max amperage
    Hey Rich, thanks for the reply. I was thinking the dash gauge registered volts instead of amps. Thanks for the correction! It puts out 14.7 volts after the car is 1st cranked and around 30 amps, then falls back to normal outputs in a few minutes (1 or 2).
