I have a shop manual that spec's staggered jetting as primary RH side as #74, primary LH side as #78, secondary RH as #82, secondary LH as #80. Are these correct? It was suggested to me to use #74 primary and #82 secondary on both. It would seem the #74 and #82 would be ok but isn't this all still too rich? What power valve no mention in shop manual. I assumed a 6.5 PV but you know what happens when you assume. Seems like everything spec'd and suggested is too big, maybe not.
'66 w/427@425HP Carburetor Jetting?
Re: '66 w/427@425HP Carberator Jetting?
Thank you Jim, that is more like what I would expect the jetting to be. The 8.5 PV, that is something I would have guessed wrong.- Top
Here are some good sources for Holley carb info:
Holley Information Table #1: Model, Kits, CFM, Venturis and Bores
Holley Information Table #2: Needle & Seat, Jets, Metering Blocks, Power Valve, Nozzle Size and Spring Colour
Jim's source was spot on... that data is confirmed in Table #2.
(NOTE: You can use 'CONTROL + F' to search by carb number.)- Top
The # 70 primary jet (.073) will not do the job using todays gas. Step up to a # 72 (.079). Keep the # 76 (.084) in the secondaries. Use a #25 (.025) pump discharge nozzle.This will cover up any off idle stumble. Also, check the metering block #. The 1st design stamped 4746 was changed to the 2nd design 4701 sometime before Jan 66, as indicated in the Chev parts book dated Jan 66.- Top
4901 is my understanding for front metering block, this is what is on my 1966, January, 2nd week original Holley 3247The # 70 primary jet (.073) will not do the job using todays gas. Step up to a # 72 (.079). Keep the # 76 (.084) in the secondaries. Use a #25 (.025) pump discharge nozzle.This will cover up any off idle stumble. Also, check the metering block #. The 1st design stamped 4746 was changed to the 2nd design 4701 sometime before Jan 66, as indicated in the Chev parts book dated Jan 66.- Top
The 4901 Primary block would be on a Jan built carb. I have some notes on these carbs as we built them thru the years, but I could use any info of what Primary blocks are in carbs built prior to Jan 66.- Top
Hi Bob,
Thanks for the great info! When you say the #70 primary jet won't do the job with today's fuel, I assume you're talking about pump gas. Will #70 primary do the job for those of us who stubbornly only put ethanol-free, high-octane (e.g. 104 Research or 98 R+M/2) fuel into their L-72s?
Sam- Top
There is only one way and that's what I do with every car I build - use a wide band reader and record your A/F ratios under all conditions. Anything less is nothing more than a SWAG. All the previous posts, including mine, are only a starting point in tuning the carb.- Top
If you can find someone in your area with an exhaust analyzer , that would be your best bet. Reading plugs if you know how. With over 40 years of being in the business, I have experienced most typical problems, and learned what works best for most applications. All my carbs are run on test engines. I have used exhaust analyzers, but know the way that a carb adjusts and engine sound work for me.- Top
Very helpful! In order to truly optimize the jetting using an exhaust analyzer, do you recommend that it be done on a chassis dyno (to simulate load) or can you get the same results revving the car in neutral?
Thanks in advance!- Top
Neither. It needs to be done on a finished car driving it under all conditions. The readings should be recorded at idle, cruising in town and on the freeway, full throttle, moderate acceleration from cruising etc. Those readings will tell you if and where changes need to be done.- Top
