Folks:
The full restoration of my '72 small block coupe is coming closer to completion. We dropped the body onto the chassis on Sunday afternoon and we feel like the shims are correctly placed. We have not yet tightened any of the body mounting bolts.
Question for anyone who has experience in doing this task: The doors fit perfectly prior to setting the body on the chassis (i.e., while on the body dolly. After sitting the body down on the chassis, the passenger side door still has the same gap spacing between itself and the body at the front, however, the gap spacing between the door and the body at the rear has narrowed more than my liking.
Is it possible that the gaps will adjust themselves once the body bolts are tightened down ? Or is it more likely there is a shim thickness issue? From our measurements the body sits perfectly straight on the chassis just sitting there on top of it.
Any thoughts?
Thanks in advance!
Roger
Any thoughts?
Thanks in advance!
Roger
