Hello all.
I bought this 92 lt1 6 speed car and drove it 3 weeks before it started acting up. 25,000 2 owner car.
first time issue car stalled while on the highway, started right back up. 1 week later car stalled would not restart. Flatbed to local station, next day mechanic said started right up, but it had an IAC code. Replaced it , he test drove a few miles ok.
Next day drove it 2 miles, died,let sit for 1/2 hour fired up and made it home 2 miles, died in driveway. Hooked up obd had ( i forget exact code think 36 ) but related to distributor. It would start for a few seconds,run lousy, tach went crazy and then die. Fuel pump runs. I smelled a hint of antifreeze, which I understand drips on opti.
Lead me to believe opti checked out. Had a more reputable shop replace with MSD dist, coil, wires, plugs, water pump, Delco icm. Now starts right up, drives great but stalls on occasion only at idle. No codes, shop says nothing shows on scope and will restart immediately sometimes with high idle.
Suspect the IAC that was installed ? the Engine coolant temp sensor ? defect in new MSD system ?
Any help appreciated !
