I need a "correct" battery for a March build 1967 427 Aircoupe! Will pay for fast shipping for correct unit! I believe it is a Delco 59. Thanks, Wade Russell 256-468-8353c.
Need help fast ! Battery for a 1967
Re: Need help fast ! Battery for a 1967
You already called Restoration Battery?
Yes sir! Ordered correct one from Tom @ Restoration Battery back in first week of August. He received all his orders from the battery factory EXCEPT R59`s !! I am up against a deadline for Bloomington Gold at Charlotte,NC about 10days from now! Aaarrgghh- Top
Call the manufacturer directly and eliminate the middleman. http://www.antiqueautobattery.com/- Top
Your next best bet is an AC Delco battery from your FLAPS with removable caps. Just be sure to get the one with top post ONLY, not the dual terminal. That will not yield you 100% originality, but it will give you enough originality points to get condition points.Terry- Top
The reproduction is going to lose 10 points in judging. Not trying to be Debbie Downer but, it is easily distinguishable from original. I point this out in case you are thinking the repop will get full credit (by a knowledgeable judge.)
Have fun in CLT. I'll be there, too.Kramden- Top
Thanks Mark! Yes sir- do know that, but I am just desparate at this time! The Restoration Battery Co. has done it`s best, for the 1 that I ordered back in August, but their supplier has delayed. Thnx agn- Top
Your next best bet is an AC Delco battery from your FLAPS with removable caps. Just be sure to get the one with top post ONLY, not the dual terminal. That will not yield you 100% originality, but it will give you enough originality points to get condition points.Vice-Chairman (West), Michigan Chapter NCRS
- Top
I was having the same panic attack trying to find an R59 for my 67 that I am preparing for a chapter event in a couple of weeks. All the main sources were backordered. I started making calls and found one in stock at a Camaro parts shop who shipped it the same day.- Top
