67 Block casting # - NCRS Discussion Boards
67 Block casting #
  • Randy S.
    • January 1, 2003
    • 586
    67 Block casting #
    Gents
    What would be the correct block casting number for 1967 L79 manuf 12/28/66?
    My reference books say 3892657 ( late 66). Seller states 3858174.
  • Rocco S.
    • December 21, 2013
    • 173
    Re: 67 Block casting #
    Randy,
    My original, one owner '67 with L79 engine with a build date of 3/30/67 has block casting number of 3892657.
    ROCCO SCOTELLARO
    1967 Lynndale Blue/Black Coupe L79, M21, G81 (3.70:1), A31, A82, C60, K66, N11, U69
    • Leif A.
      • August 31, 1997
      • 3607
      Originally posted by Randy Swartout (39156)
      Gents
      The 3858174 block was used for '66 Corvettes both 300hp and 350hp engines...if it's a Flint block.
      Leif
      • Randy S.
        • January 1, 2003
        • 586
        Leif,
        So it is probably the wrong block. My Corvette Black book (1989) says most 66's used 3858174 and late (?) 66 used 3892657. Both 300 and 350Hp 67's used it.
        I suppose 3858174 could be correct if it were dated 6 months prior to Dec 28,66.
        • Darryl D.
          • February 7, 2017
          • 386
          Leif,
          The '657 block was used mostly for small-journal 302 and 327
          engines. However, this same casting was also used for Chevy's very first 350,
          used in the 350 RS Camaro. Chevy simply machined the same bare casting for large
          journals.
          So, the 657 casting itself can be found in both small journal
          and large journal versions, but the large journal version is somewhat
          rare.
          One way to visually recognize the difference, even without using
          calipers, is to look at the bearing tangs in the main journals. The small
          journal versions had BOTH the small journal tangs and the large-journal tangs
          (see attached photo). A large journal version has only the large-journal tangs,
          since the small journal tangs were disappeared when the mains were bored for the
          larger journals.
          So, any 657
          block can be simply line bored for large journal mains if desired. I did this
          for a 383 that I built, just to take advantage of the stronger crank.
          • Joe R.
            • March 1, 2002
            • 1356
            Leif,
            Generally speaking, the '174 block was used only for 1966 production, and the '657 block was used only for 1967 production.
            However, in certain years, there have been documented cases where early production cars had blocks from the previous model year. I don't have my 1967 JG available to check whether such cases have been documented for the 1967 production year.
            Note that for manufacturing of a given model year, production generally started in late August of the previous year (August 1966 for the 1967 model year). I have seen '657 blocks that were cast in September 1966, so I know that at least some '657 blocks were being produced well before December 1966.
            While it seems unlikely that a '174 block would be used in a 1967 Corvette that was assembled in December 1966, the Corvette world is full of examples of production anomalies. I would guess that a '174 block is unlikely, but not impossible. What this means is that some additional work would be necessary to validate this as the original block. Careful attention to the pad and the casting date might provide some clues.
            • Steven B.
              • April 11, 2012
              • 233
              I think you mean the 1967 SS Camaro. It was the vehicle that debuted the 350. The SS could also be had with the RS (Z22) option which was an appearance option, including most notably, hidden headlamps, parking lights in the valance, side trim, as well as taillights without the backups, as the backup lights were located in the rear valance (and I may be missing an option or two), referred to IIRC, as an RS/SS.
              Steve
              • Ara G.
                • January 31, 2008
                • 1108
                Gents
                My original motor L79 with a build date of 12/22/66 has a 657 block FYI
                • Pancho T.
                  • July 31, 1993
                  • 238
                  My original motor L79 with a build date of 9/20/66 has a 657 block FYI
