62 Clock - NCRS Discussion Boards
62 Clock
  • Terry D.
    • May 31, 1987
    • 2690
    62 Clock
    Does anyone have suggestions on getting the clock repaired also? Never going to be judged or is it better to get a new quartz one?
  • Donald O.
    • May 31, 1990
    • 1580
    Re: 62 Clock
    I've used The Clock Works, in Eagle River Wisc. Fast turn around, fair pricing, and excellent work. They can restore it to perfection or install a quartz movement.
    Don
    • Frank D.
      • December 27, 2007
      • 2703
      Re: 62 Clock
      Don
      X2 - they installed an OEM Borg mechanical movement in my 63 clock for judging; a previous owner had put a quartz movement in...I think it was about $150
      • Rick A.
        • July 31, 2002
        • 2147
        Re: 62 Clock
        check with Joe Ray who frequently posts here
        Rick Aleshire
        2016 Ebony C7R Z06 "ROSA"
        • Pat H.
          • December 1, 1996
          • 418
          Re: 62 Clock
          If the car is never going to be judge, then I would put the quartz one in. I had my 59 clock rebuilt for the tic-toc operation for judging and after about a month it fail again. I put the quartz one back in that came with the car. Never had an issue and keeps great time.
          • David R.
            • June 29, 2014
            • 183
            Re: 62 Clock
            I replaced the clock in my '62 with a new one with a quartz movement, but I kept the old one for the next owner. The quartz one never fails and keeps excellent time - the old one was just the opposite. As others have said, if you're going to have your car judged, it's up to you.
