This is a 69 Muncie. I believe the fill or drain plugs are NPT thread. Some previous owner use a standard hex head bolt in the drain hole. I would like to replace with a correct plug.
From what little i know, NPT threads are cut at a different angle than a regular bolt. Did using a regular bolt mess the thread up so that a correct plug can no longer be used?
Don
Don
