Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508 Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737 Warning: Undefined array key "online" in .../vb/library/content.php on line 3522 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165 Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182 Warning: Undefined array key "posts" in .../vb/api/user.php on line 183 Warning: Undefined array key "posts" in .../vb/api/user.php on line 189 Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480 Warning: Undefined array key "userid" in .../vb/api/user.php on line 204 Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246 Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342 Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594 Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610 1967 Anco Wiper Blades - NCRS Discussion Boards
  • Harry L.
    • January 1, 1980
    • 96
    Will the correct Anco Wiper Blades and holders pass judging for an early 1967?
    Harry Ledgerwood
    Member #2901
    Current Region VII Director (2021 thru 2023)
  • Michael H.
    • December 1, 1987
    • 724
    Re: 1967Anco Wiper Blades
    According to the 6th edition of the 67 judging manual it says " In summary judges should expect to only see Trico blade holders on cars built in the 1966 calendar year. " So with that statement I would assume the answer would be no, so there would be a deduct for Anco holders and blades unless the 7th edition has change this statement. Maybe someone from the 67 team can shed some light on this subject.
    Mike
    • Harry L.
      • January 1, 1980
      • 96
      Mike
      Harry Ledgerwood
      Member #2901
      • Danny P.
        • Today
        Correct wiper blades on 67 the judge are looking for is Trico made in USA these are my on my 67
        • John F.
          • March 23, 2008
          • 2395
          Can't you just buy a set of current Trico wipers for a 67 corvette, and take a hit for judging like you do for a Delco battery? Current Trico plant is in Brownsville, TX. and you can buy a set at Advance or O'Reilly's per their website.
          • Tom D.
            • September 30, 1981
            • 2126
            John: Batteries are judged by standard deductions specifically called out by NCRS (on one of the laminated judging cards). Tires are treated that way also.
            I do not think the standard deduction treatment has been applied to wipers. That leaves CDCIF (stands for Configuration, Date, Completeness, Installation and Finish) as the judging process to use.
            https://MichiganNCRS.org
            Michigan Chapter
            Tom Dingman
            • Harry L.
              • January 1, 1980
              • 96
              Danny,
              Thanks for your reply. You are correct for any car after mid-January 1967. The car I am requesting help for was produced in November 1966.
              Harry Ledgerwood
              Member #2901
              • Ara G.
                • January 31, 2008
                • 1108
                Harry,
                Correct. We expect to see Trico Made in USA for Jan and later built cars. Earlier cars we expect to see just "TRICO" on the blades and they are very tough to find so the alternative is the Ancos.
                • Joseph T.
                  • March 1, 1986
                  • 169
                  Harry,
                  To answer your question: The Anco Blade pictured with peak design, brushed finish and two-line rubber insert was used throughout 67 Corvette production.... so the Anco blades should pass NCRS judging in both your early and late production cars. Good luck.
                  • Mark L.
                    • 550
                    Jay, that is my understanding also. I think we see fewer Anco on the judging field because they were more difficult to refill and thus got trashed. My opinion.
                    • Harry L.
                      • January 1, 1980
                      • 96
                      Thanks to both Ara, Mark & Jay for chiming in with this clarification. I appreciate the help.
                      Harry
                      Harry Ledgerwood
                      Member #2901
                      • Jaime G.
                        • April 1, 1988
                        • 480
                        Originally posted by Joseph Tansey (9727)
                        Harry,
                        Finally a correct response to the question, Thank you Joseph.
