key stuck in passenger door lock - NCRS Discussion Boards
  • Gary H.
    • September 18, 2018
    • 69
    During the Lone Star Regional ops judging I got my key stuck in the the passenger door lock. REALLY STUCK. Thanks to all the judges, participants, and innocent bystanders who tried to help extricate the key. I thought that once I pulled the door panel I could wiggle the tumbler and free the key. Wrong. I thought pulling the barrel and getting it on the bench would help. Wrong. I thought soaking the barrel over night in freeze-off would do the trick. Wrong. I'll go to a locksmith on Monday. But, before I do... Any ideas?
    Yes. It's the wrong key. Worked perfectly fine in the ignition for the past 2 years.
    gary...
    1967
    Convertible, L79 327/350hp, M20, Marlboro Maroon (sort of) / Saddle
  • Paul D.
    • September 30, 1996
    • 491
    Re: key stuck in passenger door lock
    Maybe some liquid graphite? Let it wick dowh the key and move the key in and out while turning it left to right. Do not apply extreme pressure as the "keys" inside are brass and could get deformed and cause worse problems. Chip.
    • Richard G.
      • July 31, 1984
      • 1715
      I would put it in a narrow jar and submerge it with my favorite penetrating oil.
      Mine is Aerokroil.
      I would purchase some lock lube and use it on all the car locks as a prophylactic measure.
      Years ago, I had a lock I couldn't get to function correctly on my 57. Pulled it and brought it to a locksmith.
      He found nothing wrong. He lubed it and it worked perfectly. Gave me the lube it lesson for free.
      Seems to be something easily forgotten on our old cars.
      Rick
      • Patrick B.
        • August 31, 1985
        • 1986
        • Gary H.
          • 69
          Got the key out. After disassembling the cylinder. Took the easy way out and ordered a new "correct" lock key set for the doors/ignition. Thanks for the suggestions.
          gary...
          1967
