I'm putting back together a 71 LT-1 . I got no radiator support,shroud or radiator with the purchase. As per the TI&JG I found a 3956109 shroud but the area for the lower radiator hose is tight. Do I have the correct shroud? I also found a harrison copper radiator 26 inch but the lower outlet looks to be in correct. I have a kaufman radiator support. Maybe if someone has a 71 LT-1 I could get a picture.
1971 LT-1 radiator fit
Re: 1971 LT-1 radiator fit
Lyle, These pictures are from a '70 LT-1 I used to own. The radiator was a copper replacement, but did match the original. It is a very tight area. I remember getting the shroud past the control arm very difficult as well. Hope these help.
DSCN0203.JPGDSCN0210.JPGDSCN0218.JPGDSCN0223.JPG- Top
